What are the differences between a 72 maverick and a 74 ? how apart are the fenders? Can the radiator from a 74 be used for a 72.....? what other parts can be used from a 74 to 72?
I have a 72 that needs the right fender ,,,,but the 74 that i have has both fenders ...can i change both fenders from the 74 to the 72?
Front and rear bumpers and attaching parts are different Radiators will interchange Gas tanks are different Lower dash tray on a 72 vs glove compartment on the 74 Interior door handles will be in a different location Fenders will interchange but need to modified in the front bumper section and may require the correct headlight buckets
the 74 is complete....can i change everything from the fromo of the car including bumper fender etc....can that be put into the 72.....?
my 72 is my first car but im having problems with it....yesterday i bought just the full body o a 74 /no motor for 100$ i dont know if i can modified the 72 from the parts of the 74....i know that the fenders dont it but if i change everything would it still work and look good.?
Fenders from the 74 can easily be used, just need to cut out a small notch. There's instructions on this forum somewhere, do a search. Most of the stuff is interchangeable except the bumpers.
About anything mechanical, like the radiator, will be a bolt in swap. The fenders will swap. You have to cut some sort of notch, but I've never found a straight answer on that so I figgure I'll find out when it comes time. The doors would be a bolt on swap(but the interior handles are diffrent and not interchangeable), you can swap the tail lights, trunk lid, windows, hood, anything like that.
