Difference between a 200 and 250
Discussion in 'Technical' started by drumgene, Jan 17, 2013.
  1. drumgene
    drumgene Member
    three way, tn.
    1975 maverick
    I'm having a hard time posting a new post, so could you help me? I have a 1975 stock maverick. It has a 6 cyl.,auto, and no AC. I need to replace the radiator and I'm not sure if I have a 6-cyl. 200-cu. or a 6-cyl. 250-cu. Can you tell me how to tell the difference. The parts store tells me that the radiators are different.
    Thanks, and sorry for asking on your post.
  2. Acornridgeman
    Wisconsin
    I moved your question to its own thread.
    The way you kept posting this same question many times into other peoples threads is bad juju - considered spamming and thread jacking. Please follow forum rules on posting .......... :Welcome:
  3. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I sent this in a PM... but I'll put it here too.
    http://www.classicinlines.com/Ident.asp
    How to identify a ford small six.
  4. mav6977
    mav6977 Member
    Wichita Falls TX
    various years
    The 250 uses the 302 Radiator. The 200 uses smaller diameter hoses than the 250. Thats why the different radiator's are needed.
  5. drumgene
    drumgene Member
    three way, tn.
    1975 maverick
    Thank you Mav6977,
    I found a tab on my block. It's a 250. So now I know which one I need.
  6. maverick75
    just get the biggest radiator you can that has the ports in the correct place.
  7. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I agree. :yup: If it were me and I had a 200 or a 170, I'd get the biggest radiator that fits, because there's no benefit in going smaller, and because I'll be one step further ahead when I inevitably yank that engine and go bigger.
  8. 1Crazy1
    1Crazy1 Member
    Los Angeles,CA
    difference between 200/250
    The 200 Intake Manifold was cast with the head. On the 170/250 you can remove them.
  9. Craig Selvey
    Nope......170 and the 250 also has a manifold that was cast with the head.
