differantial decode for 8 inch
Discussion in 'Parts Interchange' started by jnex, Apr 28, 2005.
  1. jnex
    jnex New Member
    Hello
    I'm looking to decode the following rear-end code if someone could let me know what the codes means that would be great email me at jnex@telus.net
    WDW-71 3lb
    2.79 8 530A
    Thanks
    Joe
  2. Mavaholic
    Well, its definately an 8" with a 2:79 ratio.
  3. Mercurycruizers
    Venetia, PA
    Yep! What Mavaholic said....That would be the factory ratio rearend....
  4. Acornridgeman
    Wisconsin
    In addition to the fine info above - WDW is a Maverick, Mustang or Cougar code and the 71 is probably a T1. It is a 2 pinion open differential.
    Did this come from a 74 model year? The date code 3LB is a 2nd week of November, 1973.
    530A refers to the assembly plant that made it.
    (I originally posted December build month - I forgot they didn't use I in the letter codes so I was a month off - I corrected it)
