Did I install this right?---Heater control Valve
Discussion in 'Technical' started by Blue Brick, Apr 8, 2012.
  1. Blue Brick
    Blue Brick Member
  2. 71gold
    if it is normally...closed...:yup:
  3. Craig Selvey
    If your car is a V-8, you can probably get something figured out with an aftermarket valve. The V-8 valve is different than a 6 cyl valve on a Maverick. You can see the V-8 type valve mounted to the cowl just behind the air cleaner. The V-8 valve can be hard to find and they bring pretty big bucks on ebay.
  4. Blue Brick
    Blue Brick Member
    Not sure what that means? Did I install it correct?
  5. 71gold
    it is open when engine is off. once you start engine and vac come up, it will close.
    if it's the wrong one, it doesn't matter if it's installed correctly...it will be...open...at the wrong time...:huh:
