Desktop Dyno
Discussion in 'Technical' started by Scotty P, Sep 8, 2005.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    Who has it and how does it work? I would love to see what my combo looks like "on paper". Also, who has DD thier engines and then hit the "real" dyno? How close were the #s? (I know about drivetrain loss) Scott
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    One of the Mustang sites was letting folks download a dyno program a while back.
    I don't remember the site... :(
    I DLed the dyno and the dragstrip pair.
    I had the Desktop Dyno at one time, but this program is much better, and it was free.
    It seems fairly realistic in it's predictions, but I have no real world proof.
    I modeled in my Z28 after it dynoed 318 rwhp, taking out drivetrain losses at 12%, it seemed on... but it was very tricky modeling a late model FI engine... so who knows.
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I have it. I have never had a real dyno done.
    E-mail me your complete detailed engine specs and
    I will work it up for you.
    Seth
    redcometgt@aol.com
  4. Acornridgeman
    Wisconsin
    Ask, and ye shall receive! (y)
    http://www.virtualengine2000.com/Download.htm
    Eric J
    UPDATE ******** UPDATE
    I downloaded this and it was just a basic engine calculator. If you want the real dyno functions you need to buy that download. :mad:
  5. Acornridgeman
    Wisconsin
    Seth, can you run mine when you have a chance.
    bore 4.030
    stroke 3.000
    head cc 60cc - well ported iron 1.78/1.45
    cam 214/224 @ .050 -- 472/496 lift
    gasket + deck ht .038
    piston dome +2.6cc
    gasket bore 4.060
    (10.6:1 comp)
    Holley 650 DP on dual plane
    matched springs and roller rockers
    thanks, Eric J
  6. Scotty P
    Scotty P Member
    santa rosa, ca
    Seth, cool! What do you need, exactly? I think I have all but deck height. Pretty close to 0 though.. Scott
  7. Thack
    Thack vision advicator
    Moreno Valley Ca
    The first DOS based version was within a couple of Hp and Tq from what my mustang produced on the chassis dyno (drive train loss calculated). The desk top dyno 2000 was a little more optimistic than what Tammy's Maverick produced (10-15 Hp). Still in the ball park though. I like the newer version better because it allows for head flow data. I am using it to design the perfect cam for my new engine (street Boss using Aussi heads).
    The only thing you really need to know is this is what your engine could produce with perfect fuel ratio and timing curve not what it really has in it's current state of tune.
  8. scooper77515
    Yeah, I use VirtualEngine 2000 and it is quite difficult. Requires alot of data to give you a calculation.
    What data numbers do you need to calculate HP, littlered?
  9. stmanser
    Davenport, Iowa
    i down loaded the program and installed it at work. umm...where to start...i dont know the exact specifics of my engine....maybe you could email me or icq or AIM me and explain the stuff
    but it is
    79 block from granada bored .040 over
    79 crank from granada
    stock rods
    9.5:1 flat top pistons
    .477 / .488 xtreme energy XE256H cam
    iron heads ported ....3 angle valve job ....120# springs
    edelbrock performer intake
    600 edelbrock carb .... .104 and .100 jets and .073 X .047 rods
    hooker headers
    2 1/4 dual exhaust
    Complete MSD igntion system
    thanks.. :)
  10. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Stmanser, the download above is a calculater, not an engine dyno.
  11. stmanser
    Davenport, Iowa
    ahh..that explains it...lol
  12. Acornridgeman
    Wisconsin
    Yes, the freebie download is just an engine calculator, unless you buy their upgrade. It is a useful calculator, but I thought it was the whole thing when I posted it.
    It has the best free compression calculator that I've seen. Even has input for the head gasket bore. For the compression calculator, you need to know piston bore and stroke, head cc, piston cc, head gasket thickness, head gasket bore, deck height.
  13. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I went thru 3 desks before I learned desktop dyno was a puter thang!!
  14. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    I have desktop dyno and will be putting my car on a Chassis Dyno in the next week or so. Hopefully it'll give me an idea on how accurate the program is after we figure the loss through the drivetrain. Put a Holley carb on today, so after I tune it, it's gonna get flogged on the dyno. :D Preston
  15. 74merc
    74merc computer nerd
    1974 Comet
    Engine Analyzer is a very good program. I have an older version of Desktop Dyno. Simply upgrading to a roller cam with the same specs is like 25hp all the way across the rpm range and that aint right. Headers + 30hp all the way...
    Engine Analyzer takes known numbers, flow numbers, frictional losses due to different bearing and main sizes, etc, to come up with a pretty accurate result. Even factors in accessory loss and windage and gives a ballpark on the timing per rpm depending on the octane.
    I still only use the free version 3.0, eventually I'll pony up and buy the newest release.
    Desktop Dyno no longer resides on my PC as it showed a 270* roller cam and headers producing over 400hp on an otherwise stock 302. It just doesn't work that way, I really wish it did.
