crank case venting ?
Discussion in 'Technical' started by mavgrab302, May 2, 2014.
  1. mavgrab302
    On my new engine (1995 5.0) do I use a pvc valve and a vented oil cap ? or just use a vented cap on each valve cover...
  2. baddad457
    You're better off with a PCV and a vented cap to minimize pressure buildup in the crankcase.
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    yep. and it keeps the valve covers cleaner than just using vents alone.
  4. 71gold
    agree...(y)
    ...this is the shortest answer I've ever seen you post...:Handshake
  5. mavgrab302
    Thanks guys, I'll just transfer my pvc system over to the new engine...
  6. Krazy Comet
    I'm using a open element cap on driver valve cover and PCV in the passenger valve cover, was last used on 1967 models...
  7. mavgrab302
    I have a pvc in passenger valve cover plumed to the back of the carb and a mustang breather cap with a hose attached to the air cleaner on the drivers side... This is on my old engine and seemed to work well, so I'll transfer it over to the new engine...
  8. rthomas771
    I'm running the same...but on the same valve cover on my six cyl.
  9. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Anything you can do to suck the oil fumes out of the engine is a positive,it will stay much cleaner inside.(y)
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The factory ran a PCV valve in the driver-side rocker cover, connected to a vacuum fitting on the back of the carb (or EGR spacer plate as the case may be).
    You can run an open element on the opposite side (I run a hose to the air cleaner).
  11. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Isn't that the truth! :rofl2:
  12. groberts101
    groberts101 Member
    Minneapolis, MN
    hardy..har..har.. you guys better enjoy my lack of posting time while you can and be thankful for all the extra free time it allows for you to work on your cars!
    And if we went on character counts rather than post counts around here?.. I'd be damned close to passing Frank up by now. :rofl:
