Cowel repair cost . . .
Discussion in 'General Maverick/Comet' started by mashori, Dec 7, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    What do you guys figure would be the price tag for fixing the cowel at a body shop? What kind of shop would I go to, a restoration or a body shop?
    I have 2 rusted rear fenders too, not too bad but the person who had the car before me used fiberglass. What you figure the cost would be for that to be repaired as well? I don't care if they leave it in primer after, my paint is like a 15 footer and I'm very happy with it.
  2. 71gold
    are you going to furnish a donor cowl or just do a patch job?
    Frank
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    You live in California!! Buy a Cheap rust free shell and move all your good parts over ... it would be much cheaper and better than fixing a rust bucket.
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    that's not a bad idea, I could probably find a non-rust car for cheap.
    As for the cowel I would probably just have them do the patch job. But I'm sure I can get someone here to provide a replacement cowel that's rust free.
  5. 510madmav
    510madmav Member
    San Francisco bay area
    1973 Maverick
    might be cheaper to get a welder and tackle it yourself.
  6. maverick75
    Even in cali our frekin cars rust :(
  7. rthomas771
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Jeff how did you prep the metal surface before applying this product?
  9. 510madmav
    510madmav Member
    1973 Maverick
    Don't mean to intrude, but how were you able to coat the inside of the cowl? I'm looking to do the same procedure myself.
  10. rthomas771
    I removed the fender and cut an access hole in the cowl and applied Por15 rust-preventive. After that dried I mixed the epoxy putty and patched the hole. I mig the cowl back together and put the fender back on. Cover your windshield before welding or the sparks will damage the glass. The repair kinda went like this. http://www.stormloader.com/falconccwa/leakhint.htm
  11. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
  12. Craig Selvey
    That may be true....but if I can find rust free cars out here in the rust belt, surely one can find a rust free Maverick in California. If I was in California....no way would I fix any rust, especially as cheap as rust free cars sell for out there.
  13. brainsboy
    brainsboy Member
    Tampa
    I wouldnt touch one for anything less than 1500$. Doing one correctly requires removing the windshield, fenders, removing the cowl to apron supports. Its not an easy task, and even harder to do with a vehical that is in driving condition as compared to a chassis only car.
  14. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    '74 Grabber, 302,C4,3:80 to 1 Traction lock. 1973 V8 car,LDO
    The Sept. 1992 issue of Mustang Monthly had an article titled "REPAIRING COWL LEAKS". They removed the fender and cut a hole in the cowl. They cleaned it out and using a wire wheel on a long rod, cleaned up some rust. They sprayed Metal Ready in to nutralize the rust and sprayed POR15 in. They patched holes with Duraglass. When done they used Duraglass to seal the cowl back up.
    I agree that this is not the best way,but you don't have to weld anything or repaint anything. Please don't kill the messinger here guys. I am just passing along some information.
  15. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I see what you guys are saying, when it's so easy to come by a rust free car why bother fixing something like this. But I feel a little bad about just getting rid of a car that could potentially be repaired. But I'm sure it'll be quite a lot more than $1500. For $1500 I would think someone will just patch it up with fiberglass etc .
