Conversion to 5-hole
Discussion in 'Technical' started by Xaan, Aug 12, 2012.
  1. Xaan
    Xaan Newbie
    Germany
    70`3,3
    Hello,
    what do I need to convert from 4 to 5 hole? Only needs to be replaced the wheel hub, or struts and rear axle?
    regards Nils
  2. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    As for the front you will need to replace the hub and drum assemble or with disc brakes you will need to replace spindles and rotor assemble.
    The rear will need to be replaced from drum to drum. Axle housing and bearing size are smaller on 4 lug axle.
  3. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    is the pumpkin same on 4 and 5 lug cars on 8Inch rear end?
  4. Joe Dirt
    Or you could have your axles and drums redrilled
  5. Craig Selvey
    Yes...pumpkin is the same.
  6. Xaan
    Xaan Newbie
    Germany
    70`3,3
    Thanks. To much work. I 'ill search for nice 4 hole rims.
  7. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    One consideration before you throw cash down on 4 lug wheels ask yourself if you want to do the front disk brake upgrade. disk = 5 lug
    Like JDirt said, you can have 5 lug studs put in you rear axles. Don't know how much that would cost.
  8. jlhawn
    jlhawn Member
    Olympia Washington
    1970 Ford Maverick
    I have a 28spline 8inch 4 lug from a mustang in my 1970 maverick drag racing car that i run 12.22 @ 112mph with an aluminum head 302 and TCI C-4 and I have had this rearend in my car since 1987 and all I have done is put a mini spool in it and Pro Motive 4:11 ring and pinon and new axle bearings and drag race long strong wheel studs, so keep that 4 lug it's tough and there are all kinds of wheels for it as I have Centerlines on mine, my front is also 4 lug drum (my local drag strip has a 1/2 mile shut down after the finish) the front is 4 on 4 1/2 lug pattern and my rear axles are 4 on 100mm or 4 on 4 1/4.
    bottom line it's a good rearend.
