comet tail light conversion
Discussion in 'General Maverick/Comet' started by JDM_GUY, Jan 12, 2009.
  1. JDM_GUY
    JDM_GUY Member
    San Francisco
    73 Maverick 2 door coupe, 75 JDM celica coupe, 75 JDM celica liftback, 93 ford probe GT
    i am more into the looks of the mercury comet tail light... so im just wondering if anyone has ever converted a maverick to have a comet tail lights. knowing the rear panel will be needed to be change too but is the wiring completely different from one another?
  2. chandler
    chandler Member
    Warrenton Mo
    Maverick
    The wiring is the same on both
  3. Kutlass
    Kutlass Member
    Pasco, FL
    1972 Comet and a 1978 f150
    well im not sure how. but if ou need comet tail lights i have a spare set.
  4. JDM_GUY
    JDM_GUY Member
    San Francisco
    really? the comets tail lights are separate from one another compered to the maveys.
  5. JDM_GUY
    JDM_GUY Member
    San Francisco
    :yup: sure thing, ill keep that in mind. just gotta find out if the wiring is the same or different from each own for the convertion.
  6. Kutlass
    Kutlass Member
    Pasco, FL
    well heres your answer. lol.
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I've got wiring diagrams (for '72) that show some differences in the lamp wiring, extra grounds and such for the Comet line...
    Russ
  8. JDM_GUY
    JDM_GUY Member
    San Francisco
    ths. also, just out of curiousity.... will the comet tail lights be a direct bolt on to a mavey? will there be rear panel changing involved or a little trimming of the existing light holes?
  9. Dave B
    Are the Comet tail light sockets not different from Mavericks? I thought they twist in? But then again, I've only have 1 Comet.
  10. Craig Selvey
    Yes...the wiring is the same....but the sockets are different.
  11. JDM_GUY
    JDM_GUY Member
    San Francisco
    so meaning i have to convert the rear panel to a comet for this to work?
  12. Jamie Miles
    Alto, GA
    I've had a few
    Yes, you will have to drill out all the spot welds that hold the Maverick panel in and replace it with a tail panel from a Comet. The tail panels are completely different. You will also have to replace the light sockets with ones that twist into the tail lights, and have an extra ground wire coming off them. The reason for the extra ground, is the Maverick's light sockets ground through the metal housing of the tail light. The Comet's tail light housing is some sort of plastic (maybe fiberglass?), so you have to add a ground since the socket cannot ground through the housing.
    Reesestone likes this.
  13. Kutlass
    Kutlass Member
    Pasco, FL
    corect but one thing is the light housing is not a plastic or fiber glass. it is a mattel housing. I know for sure because ive sand blasted mine and repainted them.
    but my ground wire goes on one of the bolts. maybe it got changed a couple of times.
  14. justin has a 74
    kentucky
    buy a comet and put maverick grill and hood on it (>^.^)>
  15. JDM_GUY
    JDM_GUY Member
    San Francisco
    i dont know about that, im trying out for the first time with these cars and i think ive scored pretty good with mine so... i dont think i can afford to buy another car... i already have 4:hmmm:
