Comet (novice) will need some help ...
Discussion in 'New Members Forum' started by Powerband, Nov 6, 2014.
  1. Powerband
    Powerband Member
    NY's \H/
    I just got a 1976 Comet 2dr with GT badging (?). Basically runs and drives - but will need some serious repairs to be confident on road. The engine/tranny runs great and brakes are reasonable but PO removed whole dash to get at rot underneath and cowl but evidently gave up . Floors, rear spring-bushing frame hanger, front tq bxs will need help...
    It's a 200 / automatic put to Hurst floor shifter on what's left of floor. I'm working on a 250 to put in it...
    have fun
    [​IMG] . [​IMG] . [​IMG] . [​IMG]
  2. 71gold
    :Welcome:...:Handshake:
    any pics of the dash repair?
  3. Craig Selvey
    I can see from the pictures it needs quarters too. Sounds like you need to find another car. :(
    Crazy Larry likes this.
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  5. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  6. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Looks like a good project. Some of the members on here will help you find parts. The best of all foorums to be part of.
    doncomfort likes this.
  7. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
    Welcome from SE PA
  8. mav1970
    Was the cowl repair ever finished? Without fixing that problem first water will continue to enter your interior
  9. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada! Looks like you have lots of work ahead of you, but it also appears that you are more than capable. Any pictures of the cowl repair??
  10. Powerband
    Powerband Member
    NY's \H/
    Thanks for the replies
    I'm figuring what I will deal with first to make the car roadable' and then the mods I plan. Here's a pic of the cowl issues from below ) through hole in floor). Some frame flaking around idler arm and rear spring mounts need immediate help. The cowl rotted area may be welded/patched and sealed off with heater/vents eliminated for this junkyard rescue level project ...
    >> Anyone used Mustang rear frame rail (rear spring hanger) repair pieces for a '76 ?
    have fun
    [​IMG] .
  11. Powerband
    Powerband Member
    NY's \H/
    From forum newbie:
    Can I edit a post simply?. I didn't notice wrong pic in previous PREVIEW of post and couldn't figger'how to delete it from the post once - posted.
    thanksd
  12. Krazy Comet
    Well I'd consider that as a parts car, almost as bad as Comet GT I'm parting out...
  13. Paul Masson
    1971 Grabber
    It looks like a TON of work ahead. It's worse than I thought. The rot in the frame areas would have me concerned. I believe from searching other posts on the Mustang frame rails before, I don't think they are the same, or even close. Someone had asked me personally about the same topic. Good Luck!
  14. Craig Selvey
    You came to this message board for advice....right? Take our advice from SEASONED Maverick/Comet owners. That is a parts car. Fixing that car correctly will bury you. There are sooo many rust free cars out there....why mess with one that needs so much work.
    Lots of good advice/info here:
    Fix THIS not THAT: http://mmb.maverick.to/showthread.php?t=86787&highlight=fix
  15. schroensr
    1975 Mercury Comet
    Work is such a strong word. I prefer to call it a passion of love an fun.
