Comet Gt Hood Scoop Location
Discussion in 'Technical' started by mleega1, Jul 8, 2006.
  1. mleega1
    mleega1 MAVERICK MARK
    Lagrange, GA
    1971 Maverick 2015 F150 2003 Explorer
    Does Anybody Know How Far Forward From The Rear Of The Hood The Scoop Should Be? I Dont Want To Miss The Proper Spots For The Holes. This Is A Factory Scoop. Any Help Would Be Great! THANK YOU!!!!!
  2. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    The installation will be a nightmare. Just send the scoop to me and I will dispose of it properly and save you the headache:evilsmile . j/k:D
    somebody will be able to provide the info you need(y) .
  3. Mavaholic
    I measured 1 7/8" in the center, from the back of the scoop to the edge of the hood.
  4. mleega1
    Lagrange, GA
    Thanks, That Is Just What I Needed! Have A Great Day! Or Evening!
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    make sure you check from all sides for correct position....I just did this and I had no problems....just remember, measure twice, drill once.
    The holes you drill will go threw some of the hood supports.
  6. johnfatboy
    johnfatboy Member
    toronto ontario
    1973 comet gt
    maverick 5946, where you get that hood if that is the pic of you car lookin for one for my 73 comet gt, need the functioning ram air
  7. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    the picture in my sig. is not a comet scoop. the comet scoop is on my yellow car.
    The one on the black car is a topic of ridicule and pain for many years :D
    People say its a MOPAR scoop....but it is actually a modified 429 scoop. :evilsmile
    you can cut a hole in your hood, I did that on the yellow car when I put the scoop on, it decreased the engine temp by 15 degrees when cruising down the interstate.
