cold air intake
Discussion in 'Technical' started by Longviewgrabber, Apr 27, 2009.
  1. Longviewgrabber
    Longviewgrabber Member
    ok guys ide like to put a cold air intake on my mav:clap:
    the only problem is i dont know how im going to put this thing on top of my carb....any ideas(y)
  2. Jeff S
    Jeff S Member
    NoVA
    none
  3. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    how will that be any different than a standard air cleaner? You're still pulling the air from the engine bay
  4. baddad457
    And you're going to gain zero hp.
  5. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Hit the boneyard and find a TBI Caddy. You'll know it when you see it. It will have a "hat" on the throttlebody with the same size opening as your carb, and on the other end will be a place where you can attach that ricer crap.
    (oops! Did I say that out loud?)
  6. facelessnumber
    Memphis, TN
    '71 Grabber
    Just havin' a little fun... Actually I did that once myself, which is why I know about the TBI Caddy piece. In a third gen Camaro I ran an aluminum tube from the carb to the front bumper cover. It sounded interesting, and maybe it ran better compared to the open element sucking hot air from under the hood, but in the end I just didn't believe myself anymore when I kept saying it didn't look ridiculous.
  7. Jeff S
    Jeff S Member
    NoVA
    none
    Ive had one like that, and wasnt too impressed...I never felt any real benefit to having that versus a regular air cleaner.
    But it IS for the rice burners, you can get them to buy anything as long as you say it makes them go faster...lol
  8. Maviboy
    Maviboy ForOnlyRealDrivers
    RICHMOND,CA
    74 Maverick,71 Comet
    They sell an actual "cup" that goes over the carb
  9. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    you can get a carb top hat...i dont remember the specific name of the company but they did show a power increase over the regular filter and intake
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I'd bet that a Moroso filter housing in an open scoop will show a larger power increase than all the twists and bends of a pipe flowing air to a restrictive little top hat.
    If a power increase was found, it was in comparision to a stock air cleaner housing with the stovepipe and all hooked up.:rolleyes:
  11. PaulS
    There are some filter housings that have two snorkels on them for cold air packages. In the late 60s and early 70s it wasn't uncommon to see them on muscle cars back then. Two 2 1/2" tubes running to the sides of the radiator support don't offer much restriction to the intake - there is more restriction in the K&N filter than those tubes have.
  12. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    If he cut a hole in the inner fender and tucked that thing in behind the head light it would at least be getting cooler air.
    Don't forget every LED installed on the car is good for 20HP!
  13. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    there was a guy on here years ago.....I believe his username was IVY might have changed it to fordman (from Texas if I recall correctly)
    Anyways, he had a real nice dual CAI set-up on his maverick....very sweet and that car was flying!
  14. PINKY
    Louisville, Ky.
    1970 Ford Maverick
  15. random hero
    hudson valley
    1972 maverick
    the carb hats i've seen were not restrictive at all, extreme velocity was the company, but there prices are wayy to much for an adapter for a cold air intake...lol. superiorairflow.com dynosheets (a lot of turbo cars)
