coil help please
Discussion in 'Technical' started by DRUNK, Nov 18, 2011.
  1. DRUNK
    DRUNK Member
    washington state
    1976 maverick
    ok i did my v8 swap its a 1985 302 i put in my 76 maverick 2 door i put in a points distributor my question .is about the coil i no that the neg side of it goes to the distributor were dus the pos side go dus it have to go to a wire that is hot when the key is on?or dus it need to go to a differnt place i just cant get spark to the plugs :hmmm: thanks
  2. Streamliner
    Streamliner Member
    Hot with key on
  3. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    Why dont you get a electronic dizzy for the 302 and use the stock ignition?
  4. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    If you're going to use a points distributor, the + side of the coil should be connected to the resistor wire from the ignition switch or to a wire from a ballast resistor. Otherwise the full 12 V will burn the points quickly.
    Additionally, there should be a wire from the starter solenoid that provides a full 12V while cranking.
  5. american opel
    american opel Member
    ashtabula
    1972 grabber 1967 opel kadett
    ^^^^^i agree.but also make sure it has power when cranking.some ign.hot wires arnt hot durring cranking.
  6. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Before searching for a resistor wire or wiring in a Ballast Resistor check your coil. Some Say on them they Internally Resisted and dont need an external resistor. If you have an Internal Resistor coil you can run a wire from the "I" post on the solenoid to the coil. Even if its an external resistor coil you can run the same wire but need to put a ballast resistor inline.
    The Duraspark box you took out has two positive wires the fed it, a red and a white wire. One is hot when key on and the other is hot when cranking so I dont think those would be good to use on points. But if you still have the Duraspark box and its wired in then you could just buy a Durapark distributor and hook it up and youd have electronic ignition.
  7. DRUNK
    DRUNK Member
    washington state
    1976 maverick
    yes i can get spark out of the coil but when i plug in the coil wire to the distributor no spark to the plugs you guys think the points might b tost?
  8. Bryant
    the points could be toast or just not adjusted correctly. you really are taking a step back in technology going from the dura spark ignition that the car had stock to points.
    do you a dewell meter? if so you should be able to hook it up and see what the dewell of the points is when cranking and then adjust accordingly.
  9. DRUNK
    DRUNK Member
    washington state
    1976 maverick
    thanks for your help
