Clutches (Which brand to buy)
Discussion in 'General Maverick/Comet' started by marty robbins, Mar 7, 2004.
  1. marty robbins
    marty robbins Member
    Olympia, Washington
    1975 Maverick Grabber
    One of these day's I need to replace my clutch, in the mav, it has a 3-speed on the floor and .302, would appreciate any suggestions on the best brand, just looking for a standard clutch, that will last awhile, the one in it is basically down to it's last adjustment the mechanic say's, also does any one elses kick in near the top when releasing the clutch or the bottom what is normal?:mad:
  2. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    If it's kicking in near the top, it's getting close. I just use the Autozone stock replacement. Actually, as i recall, they don't have the stock maverick replacement, so i used one off of a '79 Ford Mustang. I have a T-5 so it might be different, but it might work on yours.
  3. bmcdaniel
    I have a CenterForce Gold. It's a diaphram type that directly replaces the old Long style. Less pedal effort and about 30% more holding power.
  4. Mavaholic
    When I bought my 71 years ago (170), it also needed a clutch. As I recall I had a hard time finding one. I wanted a new one but had to settle for remanufactured. It works ok but it still chatters from a dead stop. I've never had any luck with remanufactured clutches with chattering. Other than that, they grab and wear fine. I always have my flywheel turned and replace pilot and throw out bearings when I replace a clutch.
  5. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Anybody here familar with Luk clutches?
  6. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    Luk clutches are really good. Can you get one for a Maverick/Comet?
