Clutch Safety Switch
Discussion in 'Technical' started by Erick-Mav, Jun 17, 2010.
  1. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    Did any of the manual transmission Mavericks/Comets come with a clutch safety switch similar to the neutral safety switch on an automatic car?
  2. tody
    tody Member
    cologne, germany
    no, they didn't.
    the corresponding cables were plugged together with a little wire loop.
  3. Erick-Mav
    Oceanside, CA
    That's what I thought. Thanks!
  4. bmcdaniel
    One of the worst ideas ever, requiring you to push in the clutch to start the engine with a cold, dry thrust bearing.
  5. Bryant
    every stick car ive ever started has ben with the clutch pedal pushed to the floor. i really dont think its a bad idea. the safty factor far out weighs the wear factor in my book.
  6. bmcdaniel
    Guess it's all in how you were taught. If you learned to put the shifter into neutral before turning the key... Been driving stick cars continuously for 40 years, all without "the switch", and never had a problem.
