Clutch rod?
Discussion in 'General Maverick/Comet' started by smegnl, Dec 12, 2019.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Im not sure what this thing is called, but it goes from the clutch pedal to the transmission. How do I get this thing off? I took it off the underneath and unhooked from the clutch pedal. It will slide left and right but no way is it sliding off. It looks like it will hit the master cylinder when I pull the engine. Advice?
  2. dyent
    dyent Member
    vancouver bc
    That is the Equalizer Arm (Z-bar), you will have to remove the 2 bolts on the frame, which secures the bracket, once bolts are removed, the bracket will slide off the z-bar and you can remove. Bolts should be 9/16", it is possible to remove working from top, but might be easier working from underneath, good luck!
    David
    smegnl likes this.
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    thanks. I was able to climb in next to the i6 and get the bolts. The zbar came right off. Thanks again for your help!
