Close Throttle Cable...?
Discussion in 'General Maverick/Comet' started by Maxx Levell, Dec 2, 2010.
  1. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Some of you guys mess with other Fords and may have an idea. I need a throttle cable similar to the Mavericks setup...ie how it connects on each end...I just need one a tad longer. My higher than stock intake puts mine in kind of a bind against the shock tower support, and I'd like to get a little wiggle room.
    I have a morse cable setup I can use...but the very short distance on the inside of the firewall to the pedal connection makes it kind of a pain to fab something up.
    Looking for suggestions here if any of you know of something similar that may work.
    Thanks!
  2. Mavman72
    I replaced the cable on my blue mav (Years ago) with one from a 74 ford torino. It worked fine and is a bit longer than the Mav cable.
    Note: I dont remeber if I had a peadal issue as far as hook up was concerned but it is Identicle at the carb end.
  3. Jamie Miles
    Alto, GA
    I've had a few
    Most Ford's all the way into the mid-late 90's have cables with compatible ends on them. Take a look at your gas pedal and see if it's the kind that has the pin that goes through it or the kind with the round plastic clip.
  4. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    You might try a six cylinder cable. When I first swapped in my V8, I used the one from the six and I am sure it was longer.
    Lee "THE MAV" Richart:thumbs2:
  5. strokermaverick
    strokermaverick Member
    I agree, the six cylinder throttle cable is longer than the v-8 cable, under the hood, and on the inside, the same as the v-8. That should be the remedy that you seek.:thumbs2:
  6. Joe Dirt
    im using one for a 85 mustang gt
  7. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Sweet...I have a couple of them laying around the shop SOMEWHERE! never dawned on me to look for one of them :slap:
    LMAO...that would be a different post on here wouldn't it..."looking for a 6-cyl throttle cable" :rofl2::rofl2:
