Clips For Rear Window
Discussion in 'Technical' started by RUBEN VARGAS, Feb 22, 2005.
  1. RUBEN VARGAS
    RUBEN VARGAS Member
    Houston, Texas
    1974 Mercury Comet
    2/22/05
    Where can I get clips to install the chrome that goes around the rear window of my 74 Comet?:hmmm:
    Thanx,
    rv
  2. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    Autokrafters, or an auto glass company, most likely there are more options, but those are two off the top of my head.
  3. rayzorsharp
    You should be able to go to any windshield replacement shop and get the clips you need. It's best to have an old one to take with you. There is a clip that looks extremely close to the ones you need but they are about 1/16th" too short. It's very hard to get your molding clipped in if you use this clip. I destroyed two moldings before I figured this out. :huh: That's why I say take an old one with you. Good luck.:)
  4. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    ruben you might want to try johns mustang. but take an old one with you to match up,not sure if mustang is the same. i get a lot of stuff for my car there
  5. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    Beware of the ones AutoKrafters sells that they say are for Mavericks...I bought some a couple years ago and they were the ones Ray was talking about...the glass shop I went to was able to order the correct ones...(they are usually yellow).
