chevy swap question - be gentle
Discussion in 'Technical' started by brushwacker, Dec 17, 2007.
  1. brushwacker
    brushwacker New Member
    ON, Canada
    Hi all, I'm getting my hands on a 71' Mav 2dr , 200 auto thru a trade/barter deal. Its a cool car so I want to keep it. I happen to have a ready to install fresh 400hp SB chevy sitting in my garage that I've been sitting on for 7yrs. Has anyone done a similar swap ? is it possible without cutting? I understand the stock C4 won't bolt up to a 302 anyway
    thanks
  2. brushwacker
    ON, Canada
    thanks
  3. soooulpower
    Mapleton Depot, Pennsylvania
    Wow. Now there's a bold second post. :biglaugh:
  4. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    It Has Been Done But No One I Know Lot Of Pain In The A$$ Work I Am Sure
  5. don graham
    you'll have to build your own motor mountsand tranny crossmember. a friend of mine did one. biggest pain was the distributor at the firewall. he had to cut it out and reshape the firewall. i believe he also installed a mustang ll type front end so he cut the inner fenderwells for the headers.:)
  6. don graham
    might want to cancel this thread as you already have another one. only the originator or a mod can cancel.
  7. Mavaholic
    Fat Chance!!! :D
  8. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    do it, and I'll find a camaro and slam in a CJ just in spite:evilsmile
    ah, it's your car, and you have the engine kicking around, that's what makes hotrods in my book, no dot.com-ing everything
  9. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    C4 does mount to 302's, All day long!
    I'm sure that a built 400 will bring enough
    $$ to find a decently built 302(5.0) that
    will be easier to install, and is a bolt in
    process.
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The SBC is quite a bit wider than the SBF.
    I am sure you should shave the towers at the very least.
    However, with the front sump vs rear sump oil pans, you would surely be better off with a Stang 2 suspension swap. I am pretty sure the M2 needs a rear sump pan.
    If so, then the Chevy should feel right at home. If you kept the Mav front suspension, it calls for a front sump pan, which would need to be custom made for the Chevy engine.
  11. ratio411
    ratio411 Member
    Pensacola
    Or find your nearest Stingray Vette and slap in a 460!
  12. Jamie Miles
    Sell the boat anchor and buy a 302.
  13. 71gold
    Seth,
    i think the 200 c4 bellhousing will have to be changed to the 250-302 one.
    Frank
  14. baddad457
    Well I don't condone swapping in a SBC, but if you are, then you'll want the oil pan for a mid 60's Chevy II to accomplish it. The Chevy II had a similar suspension setup to mid size Fords and had the only front sump small block chevy oilpan. You'll likely need to shave the shock towers too, to gain access to the spark plugs.
  15. rayzorsharp
    Can't find a good lookin Chevy body to use, huh. I don't blame you. If I was a Chevy guy I'd be lookin for a great body for my motor too. That's what all the street rodders are doing. :)
