carb problems
Discussion in 'Technical' started by Bob Ellis, Jun 23, 2003.
  1. Bob Ellis
    Bob Ellis Member
    Cape Coral Florida
    1969 1/2 maverick 6cyl. (170)
    Hi folks! i have a question about my single barrel carter carb, its on a 170 i6. I tried to adjust the mixture with lousey results and infact when I turn the screw in , it goes all the way to the stop and the car still runs. I guess my question is can this be rebuilt or should I buy a new one. thanks Bob
  2. jnord
    jnord senior member
    Tucson,Az
    1972 Comet 250 6
    No garantees here, but for probably less that $15.00 you can get a rebuild kit. New or rebuilt carb going to be $100.00 to $150.00 or so. When disassembled, blow out holes with compressor. ( remove idle adj screw and blow out there also.) Pay attention to float level adjustment. I'm not a carb guy, but you have to be passing gas down into the intake somewhere. A float set too high may allow gas to get get into the venturas and a accelerator pump could be defective. I don't think the hardware for an accelerator pump comes with the basic rebuild kit. Any how a kit is worth a try. Keep everything clean. Good luck Jan
  3. mavtoy
    mavtoy New Member
    Dunkirk, Ohio
    77 maverick in restore process
    Hi fellow mav freinds is it possable I could have the same problem ,I have a mav with the 250 that run great but I just had to mess with it to see if it could run better well I have it really messed up now the thing will crank forever and mabe start if you dont touch the gas peddle, if you do It wil not start for at least another day. any one know about adj. on sixes carbs thanks .
