Carb problem
Discussion in 'Technical' started by Comet-73, Oct 31, 2003.
  1. Comet-73
    Comet-73 Member
    lethbridge AB Canada
    73 comet gt, 76 comet 4 door, 71 Maverick 200/I6
    I have a problem my i know its got something to do with my carb... if i step on the gas to hard the the car wont instantly go it studders then it go it used to stall but i took it apart and cleaned it now it doesnt stall but it still doesnt go..im thinking it might be the accelerator pump but im not sure?
    Also could any one tell me what is a good bolt on carb i could buy I have a 73 comet V-8 302
  2. Old Guy
    Old Guy Member
    Carbs
    A 600cfm edelbrock is my choice for now.
  3. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    It sounds like an accelerator pump to me, but who knows? As for a different carb:
    Edelbrocks are easier to keep in tune, and can usually bolt on and go. BUT:
    They won't make as much power as a holley. Holley's are more difficult to tune, but when you get 'em right, you'll notice the difference.
  4. 357 Grabber
    357 Grabber Maverick DieHard
    kentucky
    2 71 grabbers,72 Maverick , son has a 73 maverick
    you have a motorcraft 2 barrel right??..these are the EASIEST carbs to work on that have EVER been produced...you can fix these carbs without even unbolting them from the intake ( I have even run them with the top off for adjustments)..most likely the accelerator pump is bad or restricted...napa carries the AP diaphragm for these...these carbs CAN produce a good amount of power ( they made 429's with a 2v IF memory serves) holley jets will screw into the motorcraft 2v carbs also. I have made them run really well
  5. bmcdaniel
    yeah, I always thought those carbs were neat. They're so simple that they look like they shouldn't even work. But if you know how to tune them they'll run with any Holley.
  6. hot_rod_lincoln
    hot_rod_lincoln Member
    TENNESSEE
    79 Thunderbird 302(F) 99 Windstar 3.8 V6, 85 Merc Marq302 on 20's
    How about this......79 302 2v with motorsraft 2150 carb...Rebuilt myself and now the thing smokes like hell.....Dunno, If you rev it up it flutters, and besides that if i reach over and clost the choke up about 98%, Still smokes like crazy, but the throttle responds a lot better and w/o the fluttering......Sounds like a vacuum problem, but i dont know...Can you help me?
