carb gas tank thread
Discussion in 'Technical' started by Halebopp, Apr 21, 2004.
  1. Halebopp
    Halebopp Member
    Ankeny Iowa
    Strange it didn't give me a button to reply to the thread had to restart a new one.. First of all DmHines you misunderstood me , sorry , when I replied with a question about using a vaccum pump to pull gas through the gas line, I used the term Vacuum LINE by accident, my reply saying I would not use Vaccum Line was just that, If need be I will try a vacuum Pump. Anyway just wanted to clear up the misunderstanding there, and thanks to everyone else for the tips, I did prime the carb and had it run but not more than a few seconds, I will try using carb cleaner to keep it going, I am also going to try putting more gas in, I used a 6 gallon gas can but I didn't empty it into the gas tank.
