car shuts off while in motion
Discussion in 'Technical' started by misfitruss, May 17, 2005.
  1. misfitruss
    misfitruss Member
    san francisco, ca
    1974 comet
    need help. my 74 comet keeps turning off. no power what so ever. i be riding on the highway and with out warning it shut off. i thinkin some kind of fuel starving or eletrical shortage. anyways does anybody how to fix it?
    misfit russ
  2. stmanser
    Davenport, Iowa
    i had the same problem...can you start the car...and then it will fire right back up??
    if so i replaced the coil and it fixed it.....
  3. misfitruss
    misfitruss Member
    san francisco, ca
    1974 comet
    ya it starts right back up. i replace the starter cyianoid. but that did nothing. so you think it the coil huh?
  4. Mavaholic
    First you need to determine if its a fuel problem problem or electrical. Get one of those strobe type timming lights and rig it up so you can see it from the drivers seat. Drive it till it quits. See if its still flashing before the engine RPMs stop. If it continues to flash, its fuel. If not, its electrical.
  5. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    car quits
    My sons 77 4 door did that a few times before the ignition module quit working. It would start back up in a couple minutes til it got hot again and poof, nothin. The timing light idea is a good one too....just adding my :2cents: ...Jim
  6. 71gold
    mine was the ..."clear fuel filter"...frank...:bouncy:
  7. Yellow72Mavrick
    Memphis, Tenn.
    frank
    :bouncy: :bouncy: :bouncy: :bouncy: you can tell Frank is just a happy kinda guy, lol(y)
  8. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    does the lights go out also? mine was a fusible- link by the voltage reg. also had a 67 comet sports coupe in high school that would lose all power (horn ,lights, etc) and it was a lose wire running to my after market amp gauge
  9. Mercurycruizers
    Venetia, PA
    Mine would do the same on the highway. Replaced the coil, problem solved....
  10. stmanser
    Davenport, Iowa
    my car would just shut off driving down the road....i would press in the clutch and turn the key and it would fire back up.....drive the rest of the day or sometimes another 5 miles.... but it would always start up....
    i replaced the following
    1. ignition switch
    2. starter solenoid
    3. cables
    4. alternator
    5. voltage regulator
    6. coil
    after i replaced the coil it never did it again....now i have a complete MSD system and it still hasnt shut down on me...
    good luck
