Can someone with R&C Kit give me the alignment specs?
Discussion in 'General Maverick/Comet' started by scooper77515, Feb 5, 2014.
  1. scooper77515
    My instructions with the specs are somewhere in storage. Didn't make it into the house after we moved.
  2. rthomas771
    same as your old specs
  3. scooper77515
    The installation instructions came with a set of specs, I assumed they were a little bit different from stock to help with the bite and performance.
  4. 71gold
    mine were...same as stock...:yup:
  5. scooper77515
    Alright! Makes it easy!
  6. mav1970
    What are the stock settings anyway? :huh:
  7. scooper77515
    I don't know, but when the guy puts it up on the rack and enters the year model into the computer, it will tell him where it needs to be.
  8. blugene
    Maybe.. Back when I worked a Pep Boys their equipment didn't have it. Too old. I would have to know the specs from a source and input it manually.
  9. Paul Masson
    1971 Grabber
    This is most likely the case. It has been my experience as well.
    From Mitchell On-Demand Vintage:
    Caster: -1/2 (+-) 2 degrees. Max variation between wheels of 1 degree.
    Camber: +1/4 (+-) 1 degree. Max variation between wheels of 1 degree.
    Toe-In: 7/32" (+-) 5/32"
    Toe-Out On Turns, Inner: 20 degrees
    Toe-Out On Turns, Outer: 18.39 degrees (manual steering), 18.16 degrees (power steering).
  10. John Holden
    John Holden Member
    NJ
    Not to mention if you contacted R&C I'm sure they would give you the specs.
  11. blugene
    That negative caster always made me wonder what they were thinking.. Personally I am going towards the positive side of the numbers.
  12. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    The spec's I used are: -3/8° camber, +4° caster, and 1/8" toe (in). From what I see, caster is closer to zero with manual steering but mine's a power rack...
  13. mav1970
    I only used positive caster on all of my stock cars - my thought is that negative caster is not caster at all unless you are backing up :cry:
  14. scooper77515
    Good to know, now I have it to give to the guy if he doesn't have it.
  15. 71gold
    the shop I use has it in their system.
    I gave him the specs that came with the RC-107 kit and they were the same...:yup:
