Can anyone tell me what year motor I have??????
Discussion in 'Technical' started by William, Apr 19, 2003.
  1. William
    William Member
    Heavener, Oklahoma
    1971 Ford Maverick
    I am trying to put in a what I thought to be 80's 302 motor with my 71 c-4 tranny. I went to the local speed shop and they gave me a 157 tooth 50 oz flywheel. After I got it all in and fired it up it vibrates like crazy. So what is my problem. The flywheel I pulled off said 75 351M I guess that should have told me something. Are there any casting numbers that will tell me what year motor I have. Well any help will be appreciated.
    thanks William
  2. courier11sec
    courier11sec Member
    Tucson, AZ
    casting number
    If I remember right, It's on the passenger side of the block just over the oil pan toward the back.
    the first two digits of the number are what you need to know the year.
    the first digit is the decade and the second the year.
    ex. c8 = 1968, d7 = 1977
    give me the casting number and I'll look it up for you.
    -Ray
  3. William
    William Member
    Heavener, Oklahoma
    1971 Ford Maverick
    castings
    alright I went and pulled the casting numbers and they are
    D4DE 8015 BA and below it there is these screwed into the block 4L26 this is not a stock motor and I don't know if anything could have been done to make it need a different flywheel. It has a cam and a 4 barrel.
    thanks for any help
    William
    also the flywheel I pulled has 75 ford 351 M written on it with a paint pen
  4. courier11sec
    courier11sec Member
    Tucson, AZ
    casting number
    okay.
    That is a 1974 302 block and could possibly be an 8.229 deck height unit rather than the normal 8.206. Won't matter unless you are rebuilding it or replacing valvetrain parts.
    are you sure your balancer and your flexplate match each other?
    I don't remember when exactly they changed from 28 to 50oz imbalance but I do know it was right around then.
    FYI- the casting number you gave me wasn't entirely accurate.
    D4DE 8015 BA should be:
    D4DE 6015 BA
    the middle number indicates the type of part, 6015 being the number for a block.
    My advice if you can, would be to replace the damper and flexplate with new units to be sure they match.
    hope this helps.
    -Ray
  5. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Well, sounds like you need to switch back to the 28 oz balance on your flexplate since that is a 74 302. The engine balancing weights switched in the early 80s.
    -Corbin
  6. William
    William Member
    Heavener, Oklahoma
    1971 Ford Maverick
    tranny's
    well I pulled the tranny back out in all of about 35 minutes. That's what you get when you do it three times in the past week. My 164 tooth flywheel has a smaller weight and the 157 tooth that I bought has a weight about twice the size of the 164 tooth. I don't know if this will help or not but I put both flywheels on a scale and the 157 tooth weighed just little more than the 164. the 157 tooth weighed about 6 lbs and the 164 weighed about 5 3/4 lbs.
    any help will be greatly appreciated
    thanks WIlliam
  7. courier11sec
    courier11sec Member
    Tucson, AZ
    28oz to 50oz switch
    You are right Corbin.
    I remember now, 1982 wasn't it?
  8. Corbin Johnson
    Yeah, I believe it was 82.
    William, you need a 157 tooth 28oz balance flexplate for your 74 302/C4 combo. The only thing you need to change is the balance of the flexplate you have. You can either have it rebalanced or, get another one. The 28 oz 157 tooth flexplate will be easier to find than the 50oz you have. Good luck.
    -Corbin
  9. mavman
    mavman Member
    Arkansas
    Re: tranny's
    WOW, 35 minutes? I think I remember changing a c4 at the races once in just over 30, but that was pushing it. Can I give you a call when I need someone to change my powerglide? Just kidding:D . Yes, you'll need a 157 tooth 28 OZ balance flexplate. A good clue to this would be the old flywheel that you pulled off...the 351M's were all 28 OZ balance and 164 tooth. Good luck
  10. William
    William Member
    Heavener, Oklahoma
    1971 Ford Maverick
    tranny
    yeah it would have been a good clue ,but the kid I bought the motor off of said it was an 80's so I took his word for it and went on. Where do you live at in Arkansas ?? ever go to centerville??
    thanks for the help
    William
