Camshaft Id
Discussion in 'Technical' started by 390S302, Feb 11, 2007.
  1. 390S302
    390S302 Member
    Johnstown Pennsylvania
    1966 cyclone & 1974 comet
    When I got my new 302 they sent the boxes the parts in so I would have the part numbers. The one I am most confused about is all the camshaft numbers so here goes::confused:
    Cam Lift: Int.307/Exh.318 Valve Lift: Int.491/Exh.509 Lobe Ctrs Int 107/Exh 117 Lash Hot Int HYD/Exh HYD
    SAE DUR. 289 INT/300EXH .50 DUR. 212 INT/222 EXH
    SAE TIMING BTC33 ABC76 BBC84 ATC36
    .050 TIMING BTC-3 ABC35 BBC49 ATC-7
    The camshaft is an ELGIN Pro Stock Part number E- 1017-P
    The block is a 302 Roller block with a steel roller camshaft
  2. bmcdaniel
    So what are you confused about? Sounds like a nice hydraulic roller cam for the street.
  3. 390S302
    390S302 Member
    with those numbers will a 2600-2800 stall converter be ok?
  4. igo1090
    igo1090 Member
    catonsville, md
    good ballpark. id prefer a tad more, like 3200+. jmho
    what gears?
  5. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    As long as you can get 2600 rpm on the foot brake you should be ok. I would think you could with the intake duration showing 212 degrees at .050" lift and a 112 lsa.
