C4 Trans Front Leak
Discussion in 'General Maverick/Comet' started by vernbray, Mar 24, 2010.
  1. vernbray
    vernbray Member
    San Jose, CA
    '71 Maverick Grabber
    I have a '71 Grabber with a '94 5.0L and a C4 transmission. I noticed a leak coming what looks like from behind the torque converter, so I replaced the front trans seal. I reinstalled the trans, started it up and still have the leak. Any suggestions????
    :huh:
  2. 71gold
    is it...transmission fluid or oil? could be...rear main seal on motor or rear intake seal...:yup:
  3. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    Could also mean that you have some wear on the torque convertor not allowing it to seal to the new front seal. - Matt
  4. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    If it's trans fluid,sounds like the snout on the converter is worn.Engine oil,rear main seal.Also check for cracks on the converter.
  5. vernbray
    vernbray Member
    San Jose, CA
    It is definitely tranny fluid. I did look at the snout of the converter and there weren’t any groves or wearing. I'll re-check the converter for a crack, but I didn't see anything the first time I looked.
  6. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Did you oil up snout and seal before you installed?
  7. vernbray
    vernbray Member
    San Jose, CA
    I did not oil the snout and seal. The seal did not look torn though. Do you think the seal is still usable, or should I just replace it again, this time oiling the snout and seal before I install?
  8. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Yes it should be oiled, no seal should be dry. Paul will tell you how to properly oil it up an make sure installed with any tricks.
  9. PaulS
    If you ran the front seal dry you may have a groove in the converter snout now or at least a bit of burned seal on it. Clean the converter snout with 600 grit emery paper and replace the seal. Put Vaseline or trnsmission assembly lube on both sides of the seal lip and on the converter snout before you slip them together. That way the seal will not burn up before it gets oil from the transmission. It only takes a few seconds running dry to burn a seal.
  10. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Thanks Paul,,, I wanted you to verify the Vaseline on seal on both sides as I wasn't quite sure if that was acceptable.
