C4 shifter rod
Discussion in 'General Maverick/Comet' started by 74LDO, Dec 17, 2012.
  1. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    Hey Guys I bought the hump to fount the factory floor shifter in my car and I found and bought a factory floor shifter.....Which shifter rod do I use? Is the maverick rod the same as the mustang? cougar? How will this affect the carpet?
  2. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    Yes I know I forgot its a C4 automatic
  3. Dave B
    Once the hump is in, you won't see it under the carpet. What are you going to do with the neutral safety switch?
  4. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    shifter
    Thanks Dave, I feel the Nuetral safety switch is very important. I cant tell from the pics but I think its on the shifter. If so I am after a factory harness or I will have to run my own wires. I am also worried about the collume lock. I would eventually like to swap in a flooor shift colume but for now I was hoping to find use a factory lock rod. Will it work with my long tube headers?
  5. Craig Selvey
    Pretty sure that the lock rod will not work with long tube headers.
  6. fordman57
    fordman57 Member
    Hinton WV
    71 Comet
    rod
    You need to change the shift lever in the trans for a stock floor shifter.
  7. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    shifter n rod
    Thanks for the feed back I found this diagram in the 72 shop manual. Looks like I can use the shifter with my existing lever but not the lock out rod. Dave, your running short tube headers with a floor shifter? Are you using a lock out rod? Which way does the transmission shift lever up or down with a colume shift? I think I dont like my long tube headers anymore....... Which short tube headers work best?
  8. Dave B
    I'm running shorties with a column shift on my green car. My old 74 Grabber I had to install a floor shift due to the long tube headers. You'll need to get yourself a transmission mounted neutral safety switch, and wire it in, plus lock your steering column. There should be some treads about all this is the tech section.
  9. Craig Selvey
    Dave isn't....but I am. I have the factory floor shift AT with column lock out rod...all installed with Doug Thorley shorty headers.
  10. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    thanks Craig, Would you know what part no Doug Thorleys?
  11. Craig Selvey
    I don't know the part number off hand, but they were specifically made for a MAVERICK. If you contact them...they will know.
