C4 drive pressure problem
Discussion in 'Transmissions' started by Pratt, Jul 18, 2019.
  1. Pratt
    Pratt 347 grabber
    salinas ca
    1972 grabber
    Have a 72 302 grabber with the C4 I put a B&M Streetfighter converter in it and after about 500 miles I now have a delay of anywhere from 30 seconds to three minutes going to drive once it engages it'll run all day long it does not slip don't know if I have a pressure problem bands are in adjustment no material in the pan any ideas
  2. 71gold
    :Welcome:...:Handshake:
    how many miles on the transmossion?
  3. Pratt
    Pratt 347 grabber
    salinas ca
    1972 grabber
    60 k
  4. Krazy Comet
    Usually delayed engagement is due to valve body gaskets, bolts could be loose.
  5. miketx
    miketx Member
    TX
    GMC Envoy
    Hard seals in the forward clutch or low fluid level.
  6. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Just to clarify. Is it no 2-3 shift or no engagement?
  7. miketx
    miketx Member
    TX
    GMC Envoy
    No it doesn't.
  8. Pratt
    Pratt 347 grabber
    salinas ca
    1972 grabber
    I pulled the transmission out put new seals in the case for the kickdown lever check the valve body bolts on the way back in torqued them properly they weren't loose Now I've got a delay in the drive that could take anywhere from 1 to 20 minutes for it to go into drive once it goes into drive I'm good to go until I shut it off again no problems could happen one time could happen every time
  9. Rick
    Rick G8I operations
    Ocala, Florida
    Not what you want to hear but I would pull it out again and check the pump, Sounds like the pump gears got boogered with the new converter.
