C-4 to aod conversion done
Discussion in 'General Maverick/Comet' started by Ol Maverick Man, Feb 4, 2010.
  1. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    Thanks to all the great information from this forum, I have a AOD in my Maverick in place of the C-4. Frank's rear trans. crossmember looks like it came from the factory. A perfect fit. Napa was able to convert the OEM flexplate number given here on the forum to one they had in the warehouse. Slight modification to the exhaust (right side). Shortened the driveshaft one inch. It was necessary to remove the right header during the installation. Thanks to all that replied to my questions. Caught a couple of dry days and was able to drive the car.
  2. mavgrab302
    Congrats, that's awesome..........
  3. sierra grabber
    sierra grabber Certifiable
    northern nevada
    AWESOME, CONGRATS! would you be able to post the converted flex plate number for future reference? which weight balance was it?
  4. Ol Maverick Man
    Wallingford, Ct.
    The OEM flexplate number I used was EOAZ 6375 A. It was 50 oz. with 157 teeth.
  5. mean_maverick
    wow, never knew such a beast existed. thanks for the info!!!
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I would like to run an AOD but they don't allow you to have manual control of 2nd gear. Seems like a goofy set up but I guess it worked. Are there any tricks to work around this aside from getting the E4OD out of a 2wd pick-up?
  7. Ol Maverick Man
    Wallingford, Ct.
    I noticed the same thing you are talking about. I was hoping that it will stay ln under full throttle until I am ready to shift. Mine has a B&M shift kit. When I drove It was with a light throttle.
  8. Alan Duke
    Alan Duke Member
    Houston, TX
    1973 Maverick
    PaulS may now a way around that.....let's see if he chimes in on this one...........by the way CONGRATS!!!!
  9. 71gold
    "they don't allow you to have manual control of 2nd gear."
    :yup:...i have a full race AOD.
    ...manual shift
    ...lockout OD
    ...transbrake
    (and...it's also for sale)
    went to a Gearvendor OD, something the little Lady can drive...:thumbs2:
    ...:outtahere::chirp:
  10. 71gold
    ...:Handshake...(#32 )
  11. sierra grabber
    northern nevada
    i was told you could shift to OD and then slam back to drive again under throttle to hit second manually? sounds tricky but i have dragger friends who dont think its a big deal...
  12. Bryant
    thats a good way to brake the trans. ive know lots of people who have manualy shifted a stock aod and had it fail shortly there after. there are susposed to be some mods that can be done to the trans so it can be shifted manualy and not die.
  13. sierra grabber
    northern nevada
    that was what i was thinking as they told me this...
  14. PaulS
    The "epoxy mod" will give manual control over 1 and 2 gears butyou need a OD lockout to keep it from going into OD. The "epoxy mod" shift pattern is 1, 2, 3-4(automatic). There is little trouble with this because OD doesn't come in under power. there is a problem if you shift back to 2 from OD though.
    With the standard shift pattern (1-2, 3, 4) you can drop shift back to 1 when it shifts to 2nd and that will hold it in second until you shift back to 3.
    You do need to be sure that you are getting good throttle pressure at all times when using either shift system or you will burn up the AOD.
  15. sierra grabber
    northern nevada
    :dizzy: i think that is why most my "racer" friends stick with a c-4 or chebby 2 speed for quarter racing... just a couple that mess with AOD and its on their "street cruiser"... im still considering the AOD for the future though... :oops:
