C-4 Mechanical Linkage Bracket?
Discussion in 'General Maverick/Comet' started by John W, Jan 14, 2014.
  1. John W
    John W Member
    Walkerton Ontario Canada
    1932 Ford Roadster Hot Rod 1977 Maverick
    Following is a quote from "Swapping a late model 302 into a Maverick or Comet" - by Charlie Ping
    So when they redesigned the 302 block in 1981 they left off the pivot point for the older mechanical linkage. This is a problem if you are using the factory mechanical linkage.
    Total Performance sells a bracket for this purpose, but they are not difficult to fabricate. Here is a close up of mine (viewable in the top picture as well).
    I am looking for this bracket? Has anyone used this bracket, and if so, where did you purchase it?
    I have a 77 Maverick with automatic column shift and I a later 302 block.
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    It was my understanding that they were talking about manual trans cars even though it says C4.
  3. yellow75
    Tillamook Oregon
    You are incorrect, if the car has a column shift you still need the bracket because the linkage still ha a pivot point on the engine
  4. John W
    John W Member
    You are correct. Somebody has manufactured a bracket and I am trying to find out where I can purchase one. The tech article said Total Performance has them, but when I Goggle Total Performance ( I live in Canada) I get a exercise site selling tread mills. I am way too old for that.
  5. Krazy Comet
    I have one on mine made up from 5.0 water pump back plate... No don't think I'd want to use this for a clutch pivot, but for auto column linkage it's fine...
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I am sure any Mustang Parts Supply company has them
    Example
    www.mustangdepot.com
    Part number TRA-658-538
