Bumper & bracket help needed
Discussion in 'Technical' started by MICHAEL DAVIS, Jun 15, 2012.
  1. MICHAEL DAVIS
    MICHAEL DAVIS Member
    1973 Ford Maverick
    100_1309_original.jpg 100_1312_original.jpg 100_1311_original.jpg 100_1310_original.jpg
    Yes it mounted to my deck, but thats how it would fit on the chassis, so im have'ing trouble as you can see the bumper would never be level and id have to do some serious bending. If there correct let me know ,the brackets that I have are 1972's and im a lil frustrated Bumper is fiberglass 70/72 year. I resolved the rear bracket problem, I put the original bumper on and it fits like the new fiberglass one so im good, front on the other hand..
  2. 71gold
    let me run and look at mine...:yup:
  3. Craig Selvey
    From a quick glance, it looks like your inner bracket is bent UPWARD. The top of the bracket should be a straight line from front to back.
  4. MICHAEL DAVIS
    1973 Ford Maverick
    Let me know Frank and Picture if possible. Thanks .. Craig thanks also once I know for shure its off to the acme:biglaugh: anvil and a torch! lol
  5. MICHAEL DAVIS
    1973 Ford Maverick
    Anyone with some photos would be helpful. Thinking of sending bumpers back at this point..
  6. Dave B
    There are some NOS brackets on Ebay, you'll be able to compare yours with.
  7. MICHAEL DAVIS
    1973 Ford Maverick
    Thanks I was trying for a long time last looking others builds but not one bracket. Thank again ill go check them out
  8. MICHAEL DAVIS
    1973 Ford Maverick
    Ok did find that bracket on ebay, not much help other than there is one more hole drilled and my outiers looked like a comet I stumbled across. Did a lot of searching last night a good 4hrs+ but nothing. Anywas here is my next question and a picture to fallow. Should the flatest surface of the bracket be bent, in the photo you can see a big arc or bend they are both this way.
    Thanks for any info!
  9. Craig Selvey
    No...they should not be bent.
  10. MICHAEL DAVIS
    1973 Ford Maverick
    Great, spend 75. for three bent brackets. Someone has a set but id have to send cash and wait for the part.. I found one in a junk yard im going to call today and see whats left
  11. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    ya you do have some bent brackets, they should all be straight except for a single bend near the mounting points on the car(big holed side)
  12. MICHAEL DAVIS
    1973 Ford Maverick
    Here is a few more. Seth!
    100_1319_original.jpg 100_1321_original.jpg 100_1320_original.jpg 100_1323_original.jpg
  13. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    ya looks like your inside bracket is definitively bent, you probably straighten them out in a vice without to much trouble. good luck
  14. MICHAEL DAVIS
    1973 Ford Maverick
    The problem is I dont know what im straighting, ive got a few ideas but.
