break light problem and turn signal
Discussion in 'Technical' started by disco123, Dec 23, 2009.
  1. disco123
    disco123 Member
    las vegas
    71 comet with v8 conversion, hat 2 gts new in 71 and 74
    just replaced my break light switch- i have no leftrear break light and left rear turn signal all other markers and lights work ,the side markers are fine when turn signal is on hmmm i did cause a spark when replacing the switsh, i touched somehting under he dash, i traced the wires and maybe i have a short where one of the break light wires go s to the steering colume??
  2. rthomas771
    Make sure you have a good ground at the brake lights
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Does the left front signal work? If it helps the brake light switch sends it's power to the turn signal switch and then it goes out from there. You might try turning on the right t/s and check the brake light then. If it lights you may need to replace the t/s switch or clean it real good if it's original. I had to chase a similar problem with my GTO and it drove me nuts!!!! Good luck.
  4. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    I had that same problem too, it was the turn signal switch. I ended up buying a NOS switch assembly that replaces all of the harness in the steering column too, just getting another cam for it will not correct the problem.
  5. disco123
    disco123 Member
    las vegas
    i think your right, i just got a colored wireing diagram thanks
  6. disco123
    disco123 Member
    las vegas
    all the lights work side markers, break front signals- i traced the wires and your right they allllllllllllllllll go to the turn signal switch , ill dig into it this week thanks
