Brand of strut rod bushing?
Discussion in 'Technical' started by Blue Brick, May 9, 2014.
  1. Blue Brick
    Blue Brick Member
    What brand of strut rod bushings do you use? Nothing looks like an OE replacement, more like a universal fit.
  2. mercgt73
    I have never used them, but MOOG sells replacement bushings #K8157
  3. Blue Brick
    Blue Brick Member
    I saw that one, it just didn’t look right.
  4. Blue Brick
    Blue Brick Member
    Napa looks the best, but there is no warranty. Excludes normal usage.
    Part Number: NCP 2749051
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I installed NAPA bushings, and yes, they don't look like the OEM. The guy at the parts counter claimed they are an improved version over the O.E. I have no idea if it's true or not.
  6. Blue Brick
    Blue Brick Member
    Ok, sounds dumb, but how did you install them? Which way was the bushing?
  7. Blue Brick
    Blue Brick Member
    I found 1991 Thunderbird Strut rod bushing. Inner Diameter is .90 inches (per Rock Auto)
    1977 Maverick Inner Diameter is .94 inches. (per Rock Auto)
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    What does 1991 Thunderbirds have to do with anything?
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    If I remember correctly, they are the same on both ends, so it doesn't matter. The OEM bushings are not the same at both ends.
  10. Blue Brick
    Blue Brick Member
    Cross-referencing and parts interchangeability.
  11. bmcdaniel
    Moog, period.
  12. baddad457
    Just do NOT install urethane bushings in the strut rods. Rubber only. Use Urethane and you will not be a happy camper when the strut rods break.
  13. Blue Brick
    Blue Brick Member
    What about Thermoplastic?
  14. baddad457
    I've never heard anything about that kind, only Urethane. Do a search on the classic Stang forums on Urethane strut rod bushings, you'll find many instances of the rods breaking with the use of them. I would do a search on thermoplastic bushings as well before using them on strut rods.
  15. darren
    Moog for all my front end parts. Strut rod bushings fit perfect.
