brakes
Discussion in 'Technical' started by daydreamer, Aug 14, 2004.
  1. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    Hi guys. Am just finishing a disc brake swap. the front brakes have drained completely of brake fluid. Can I open up the rear bleeders on the drum brakes and let gravity drain all the old fluid out so that I can put in new synthetic fluid.It would be easier that forsing out the old fluid with synthetic fluid. Thks Ron:confused:
  2. Mercurycruizers
    Venetia, PA
    Why would you want Dot 5 fluid? Dot 3 is all you need. You can gravity bleed the rears. Then you'll need someone to operate the pedal a few times to make sure all the air is out.
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Ron, If you had one of those power bleeders,,, or what I call um,,, by myself bleeders. You might get all the old fluid out. I dont know if it will gravity bleed all the way or not.
    Dan
  4. daydreamer
    Oshawa, Ontario
    1972 Ford Maverick
    Thks for the reply but the old fluid is very dirty and i dont know how old it is.Also Im using synthetic's in the rearend and synthetic's dont heat up as much and therefore have a better stopping distance .no fade
  5. Mavaholic
    From what I read, synthetics don't work as good as standard brake fluid. The advantage is, it doesn't absorb moisture like standard brake fluid. Personally, I put synthetic in my Sprint and seems to work fine so far.
  6. Dan Starnes
    West Central IL
    And I can attest to that fact, from 100 mph braking to the return road at the Muncie dragstrip, it stopped just as good as my car that has 4 wheel disc brakes. My next car I do will have synthetic fluid.
    Dan
    ps the big difference in me adding disc brakes to the rear is, when I slow down hard,, it does not nosedive whatsoever.
  7. daydreamer
    Oshawa, Ontario
    1972 Ford Maverick
    Thanks for the replys guys. I will try the gravity thing and if not then I will force the old fluid out. Im using that new Royal Purple synthetics, supposed to be just great stuff. All the people I know that have high performance vehicles have switched to Royal Purple and all have nothing but good reviews. Thanks Ron
  8. mfp mav
    mfp mav Interceptor Member
    anaheim, california
    71 grabber v8 black on black. police intercepter logos. ttd wheels
    will synthetic fluid help or usable at all in all drum cars? mike
