Brakes again...
Discussion in 'Technical' started by Swiz2588, Apr 24, 2013.
  1. Swiz2588
    Swiz2588 Member
    Edmonton, Alberta, Canada.
    1974 mercury comet, 1973 ford maverick grabber, 1975 ford maverick 4 door.
    Hi, so I found a 1977 mercury comet doner car. It has power drum brakes all around. My 1974 comet has manual drum brakes. Can I bolt the whole booster/master on to my 74 with no major changes?
    Thanks
  2. rthomas771
    I think I read that the pedal support and pedal will also need to be swapped because of the angle of the master cylinder.
  3. Craig Selvey
    That is correct. Some of the brake lines are also in different locations, as well as the prop valve.
    Converting to Power Disc Brakes:
    http://mmb.maverick.to/showthread.php?t=19107
