Brake trouble . . .
Discussion in 'General Maverick/Comet' started by mashori, Aug 29, 2010.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Have been having some interesting trouble with the breaks. Sometimes I can push the pedal down only a little and it breaks and sometimes it goes all the way to the bottom before stopping the car. Sometimes it'll stop the car with a little pressure and as my foot is on the break pedal the pedal travels further down. Weird woodoo stuff.
    We instpected the breaks and everything seemed ok so we thinking it's the master cylinder. We stopped by CNC Brakes and talked to Chuck who is gonna sell me a master cylinder. We should be able to get it done this next week if all goes well.
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I think your on the right track, definately sounds like the master is on the way out.....
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    it hasn't been too bad so I've decided to cont driving the car. Am I being ignorant or is it safe?
  4. Dave B
    When the pedal goes all the way to the floor, you can decide for yourself....
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I wouldn't chance driving it like that.....
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    ok. probably not a good idea. i'll park it.
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Far better to park it until you get it fixed, it would be a shame to wreck because the brakes gave up completely.....
  8. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Or get you a good pair of Flintstone tennis shoes to whoa it down.........................nope that idea won't work either. Fred Flintstone never wore shoes!
  9. simple man
    simple man Member
    Bunnell,Florida
    Worn seals in the master cyl! If you hit the brake fast,it will hold. If you brake normally pedal holds for a second and falls to the floor. Totally unsafe,quit driving the car and get a new master cyl!!!:)
  10. CaptainComet
    Yeah, MC sounds like the problem. If you can pump the pedal a few times and get pressure back, that is another symptom of a worn-out MC.
  11. jncastell
    jncastell Member
    Ogden, Utah
    1974 Maverick Grabber Clone
    You better listen to these guys I was stopped at a red light I was gonna turn right leaving work (Rush hour traffic) and my master cylinder gave, my car shot through the intersection I jerked the wheel to the left to go straight luckly no one ran the red light. Pretty scary.
  12. DVCRobin
    DVCRobin Member
    Nashville, TN
    1976 Maverick
    Was having the exact same symptoms with our car while driving it home the day we bought it. Replaced the Master Cylinder and all is fine now.:drive:
  13. justin has a 74
    kentucky
    You could always drive with the ebrake on if you really need to.
  14. mojo
    Brakes
    I agree w/ all those who say stop driving until u get the master.
    While ur at it, I wud change wheel cyl and brake hoses too if u have'nt already done so.
    IMO brake work is first priorty - I see guys spending thousands of dollars under their hoods, on wheels and tires, paint jobs and have a brake system w/ single res. MC and four wheel drum brakes. All the time and money spent is meaningless if u wreck the car cuz u can't stop.
  15. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Today we bench bled the master cylinder. Pretty simple process. Plugged the holes that go to the break lines, then poured Dot3 into the reservoir and just pumped the piston back and forth. Got some bubbles. After a while there wasn't much piston travel and no bubbles.
