brake swap
Discussion in 'Technical' started by 71nogo, Oct 26, 2010.
  1. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    I own a 71 grabber with drums all the way around. I want to change to front disc. So i stopped by my local pull-a-part. they have a 75 granada and a 76 maverick both with front disc. but the guy behind the counter tells me it wont work. im thinking if i take the spindle, rotor, back plate,caliper i should be good, no? anyone have some insight on this?
  2. yellow75
    Tillamook Oregon
    Get the outer tie rod ends, proportioning valve, brake hoses and steel lines and brake hose brackets as well
  3. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Take them off of either, which ever he thinks is cheaper. Take the whole spindle off the car with all brake parts attached. I even took the hardlines off the frame to make sure the rubber lines bolted up and were in the right location. Lots of info on here and inthe tech article on how to install but long story short, they will work.
  4. bmcdaniel
    I used 76 Mav parts for my conversion, MC, spindles, rotors, calipers, hoses, outer tie rod ends.
  5. 71gold
    i would get the spindles...MC, rotors, calipers, hoses, outer tie rod ends i would get new. no need buying the old stuff and having to replace it.
    where ever the deal is...
    ...:yup:...
  6. mojo
    I agree. Do it once and be done. Nothing more important than stopping. :clap:
  7. maverick75
    I would get both setups. They sell for quite a bit of money. Sell one set and itll cover the price of both.
  8. Ryan
    Ryan Ford Addict
    Phoenix Az.
    If the calipers are cheap enough take them too to turn in, probably gonna be cheaper than having to pay the core charge when you go to the parts store to buy the rebuilt ones. Same with the master cylinder. But rotors can be left since they will charge for those since they have scrap value but will be no use to you since they can be bought new.
  9. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    thanks everyone. my main concern was that the spindles would fit.
  10. justin has a 74
    kentucky
    I have granada brakes on my car so yes. Tell him you will take both haha!
  11. maverick75
    The granada, maverick, comet and monarch(pre80) all use the same spindles. And they swap over to about 8 other models.
  12. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    cant buy both unemployed!
  13. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    In that case, stick with drums for now :hmmm:
    Or, get one set, put them up for sale to make some cash, then get the other set.
  14. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    thats something to think about!
