brake pedal clip
Discussion in 'Technical' started by quickboss, Oct 23, 2008.
  1. quickboss
    quickboss Member
    South Eastern Ohio
    71 Grabber 54,000 original miles and 71 Maverick race car
    Can anyone e-mail me a schematic of the brake/clutch pedal assembly for a 71 maverick? My son's 71 brake pedal lifts up now and there was a hair pin clip laying on floor mat but i can not really see where it goes with out removing lower package shelf or removing steering column. My car doesn't have factory pedal assembly any more. It's tube frame chassis now.
    Or if someone can tell me how the brake light switch and master cylinder attach. I know this sounds stupid but I can't see how it is all attached standing on my head in the floor pan.
    Thanks, quickboss quickboss@earthlink.net
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
  3. quickboss
    quickboss Member
    South Eastern Ohio
    Thanks! This is how it is attached and there is the retainer clipped in place bu the pedal will still lift up from beneath. Any suggestions?
  4. maverick1970
    Missouri
    It is possible that the retaining clip is missing from the rod where it is inserted into the piston of the master cylinder. If this is the case it is a potentially dangerous situation. If it were to fall out completely the car would have no brakes.
  5. 71gold
    i agree with Allen. it sounds like the rod is loose on the M/C end...
    not good when that happens...
    ...:yup:...
  6. quickboss
    quickboss Member
    South Eastern Ohio
    Where does the retaining clip go on the master cylinder push rod ? Its very difficult to see and I don't have a shop manual. Any suggestions for a good shop manual?
  7. quickboss
    quickboss Member
    South Eastern Ohio
    I appreciate all the help !
  8. maverick1970
    Missouri
    The clip is about 1/4 inch from the end of the rod on the master cylinder end. The only way you should be able to see it is by removeing the master cylinder. You should not be able to remove the master cylinder without disconnecting the rod from the pedal.
  9. quickboss
    quickboss Member
    South Eastern Ohio
    thanks, I 'll look at it tonite.
