brake drums question...
Discussion in 'Technical' started by scott, Jan 5, 2005.
  1. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    my drums in back are warping... i figured this out when i pulled away from the diner and didn't release the parking brake fully... the car kinda lurching back and forth a bit until i let the brake off all the way. so in light of seeing how much drums cost, any body know how to tell if a used drum has some cutting left in it? is there a thickness measure or maybe a diameter measurement that i could use? looks like another trip to the yard. (darn)
    thanks
  2. 71gold
    scott,
    there is a thickness it can only be turned to...it should be on the lip of the drum...frank...
  3. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    hmmmmmmmmmm, just take the shoes out, "we don't need no stinking brakes", besides, all they do is slow you down:D
  4. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    New drums are cheaper then an accident. Buy new from a NAPA or good parts store. Drums are not that expensive. Better safe. Have you checked to see if your drums can be turned and saved or are they to thin already? A good parts store can turn and measure the drums for you.
