braided aircraft fuel line
Discussion in 'Technical' started by Yellow72Mavrick, Feb 17, 2006.
  1. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    I have a friend who works at Memphis Aero near the airport. He tells me he can get steel braided 3/8 inch fuel line with or without fittings. It would be nice to run a flexible fuel line through the maverick. He says he can get me around 25 ft or so. If it works for aircraft it should work on a car, wouldn't you think???
    :confused:
  2. Jamie Miles
    Alto, GA
    I've had a few
    I don't know, but it sure would make it alot easier. It's a PITA trying to duplicate the bends of the stock line on a piece of 3/8ths brake line. Just have to be careful to mount it in a way so that it dosen't get kinked or closed up.
  3. igo1090
    igo1090 Member
    catonsville, md
    3/8 is probably -6, so it'll work well. can make life much easier & meets the safety rules at the track.
  4. Yellow72Mavrick
    Memphis, Tenn.
    cool deal, I'm likin it...
  5. don graham
    i would think it would work. makes it a lot easier. sounds like the price is right too??:)
  6. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    get the fittings while you are at it,even if you don't use them they are expensive to buy.
  7. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Make sure that it will fit through the area at the torque boxes without
    chafing(sp?) or rubbing. Such a deal.
    Seth
  8. AUSSIEBJ
    AUSSIEBJ http://mmb.maverick.to/at
    NEW YORK
    70 Mav old race car project,70 mav 460 ,C6 9" posi 4.11rear SOLD
    There is a problem here aircraft wire braided hose is lined with teflon not rubber and is hard to make your own lines up with out the propper equipment so check before you get to excited..
  9. Yellow72Mavrick
    Memphis, Tenn.
    AUSSIEBJ my friend has the equipment and says he will make up the correct hoses for my needs. He works at Memphis Aero in the shop so he has access to the machines...Jim
  10. AUSSIEBJ
    NEW YORK
    Ok that will work, good luck.. hay any time friends can help out that means more money for other stuff
