Borgeson steering kit
Discussion in 'General Maverick/Comet' started by Miguel Arzola, May 11, 2019.
  1. Miguel Arzola
    Miguel Arzola Member
    Long Beach Ca.
    1975 maverick Grabber
    Hi that anybody have use this steering kit looks good but I don’t want to go wrong on buying this kit , thanks on your opinions
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Mojo has used it, I believe he has a thread on here about it.
  3. RMiller
    Kennewick, WA
  4. Miguel Arzola
    Long Beach Ca.
    Thank you RMiller
    RMiller likes this.
  5. mojo
    mojo "Everett"- Senior Citizen
    If you don't have factory PS this is probably the best, most practical way to go. Rack & pinion probably little more involved. If you have PS you can always rebuild. I'm assuming you have seen my thread mentioned above post?
    I did have to add some shims to UCA arms to caster out to 3+ deg. Also, If you go this route you may have to add some shims to the pressure inlet to decrease sensitivity, if you use their Saginaw pump. Borg offers shim kits for this purpose. My pump came w/ 2 shims, wound up adding 3 or 4 more -- don't recall if 3 or 4.
    Forum member "Cometized " Chip also uses the Borg setup, but he uses Saginaw GenII style pump and told me he didn't have any issues, did not have to add shims to reduce sensitivity.
    Miguel Arzola likes this.
  6. Miguel Arzola
    Long Beach Ca.
    Mojo thank you to take the time to write about this set up I would take in consideration your comments and yes my maverick has factory p/s the reason I like to install this setup to have more clearance for the headers and little cleaner under the car
  7. mojo
    My car is also PS; I found their hoses too short for my comfort, wound up having new pressure hose made and extended the return line. I used the stock PS drag link. I had long tube headers when I installed Borg., have shorties now. My car has OE floor shift - so, no issue w/ linkage clearance. I had to slightly modify the steering column plate where it mounts to floor board. Using this setup really cleans up the under hood & under car.
  8. Miguel Arzola
    Long Beach Ca.
    See mojo what you said,that was my vision ahead on my road to restore this vehicle thank you for let me know what you encounter to install your setup I will have it in mind have a good day thanks
