Bent center link?
Discussion in 'Technical' started by littlecrow, Oct 24, 2012.
  1. littlecrow
    littlecrow Member
    Caneyville, Kentucky
    1970 Ford Maverick
    Hey guys, I just got a 1970 Maverick with manual steering and I've been replacing the whole front suspension on it for the past few days. I got everything replaced and on the car now, until I got to the center link. I'm not sure what shape it's supposed to be but to me it looks really bent. So what do you guys think?
  2. 71gold
    I say straighten it...without heat...:yup:
  3. Craig Selvey
    Yes...it is bent. If you don't want to mess with it, I have a BRAND NEW one I could sell you. Email me DIRECTLY (see below) if I can help.
  4. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    You can also get them brand new from Laurel Mountain Mustangs.
  5. Acornridgeman
    Wisconsin
    Looks like someone drove into a tree stump or a big rock sticking out of the ground. You could use a hydraulic press and put it back. If it were my car I would just buy a different one and be done with it.
  6. littlecrow
    littlecrow Member
    1970 Ford Maverick
    Yeah, it was like that when I got the car. The guy had to have hit something while backing up and somehow that was the only thing that got bent. Unfortuntly though, he also had the car aligned with the bar like that, so I want be able the match tie rods length up so I can drive it to an alignment shop. I'll end up buying a new center link because I just don't trust having that one re-bent and not knowing the specs.
  7. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Good choice, re-bending never works out in the long run. I've worked for a lot of cut-rate employers that when having me repair and refurbish machines would have parts 'repaired' rather than replaced... usually just wound up replacing them a few weeks or months later anyway. Always had to remember to not shove it in my bosses face if I didn't want to get fired. err... This part is too important for making your car work, get a new part.
  8. Craig Selvey
    Wow.....I can't imagine that would work...but maybe it did.
  9. 71gold
    I'm with you, as short as that is they would have had to screw the ends off to make it long enough to get the front end in spec...:yup:
  10. 71gold
    it's just a rod, straightening it without heat would not hurt anything...
    I would run it on my car...:drive: :chirp:
  11. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Sorry once you get past a certain bend radius the damage is done at a granular level. Bending it back without heat just pushes the microfissures back together but does nothing for the elastic stresses put on the rod. Heating and re-tempering would be the best fix but even then the rod would never be able to handle the stresses it could prior to being bent. One day you would be driving down the road in a corner and it would snap.
