Bell housing ?
Discussion in 'Technical' started by mavgrab302, Feb 19, 2013.
  1. mavgrab302
    OK guys, for my T-5 swap do I need a original bell housing or the bell from a 84-93 mustang ? My 302 is from my 74 mav... Will a newer bell bolt up to my 74 302 ?
  2. rthomas771
    If you already have a manual transmission then use an adapter plate on your bell housing...unless if you want to burn cables every thime you turn around. To answer your question you need the T-5 bell housing and yes it fits a 302
  3. mavgrab302
    Thanks, no I don't have a bell yet... I'm going full hydraulic from Modern Driveline....
  4. baddad457
    You need the T-5 bell.
