Been gone...
Discussion in 'General Maverick/Comet' started by PAINTANK, Jun 1, 2010.
  1. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    My beloved Comet decided not to start after work a couple months ago. I swapped in the wifes battery and got it home and there it has sat since.
    So...an update:
    Wire shelving grille removed.
    Turn signals removed.
    Small bumper installed.
    EGR spacer removed(original FUBARed)
    Cranks but doesnt start.
    Drains the battery attempting to start.
    Still looks awesome and makes me tingly in that special place when I see it.
    Thats about it.
  2. JHodges
    JHodges thumper
    Dora Alabama
    I thought you was gonna say you sold it. You will get it figured out and working good soon
  3. PAINTANK
    1973 Comet 2 dr
    I considered selling it and buying a CAMARO.
    Not really.
  4. PaulS
    When you removed the EGR spacer did you plug the EGR port in the intake? If not the that may be part of your problem - exhaust gases getting into the intake will keep it from starting. You can use a drill and pipe tap and then plug it with a flush fitting pipe plug.
  5. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    PAINTANK, good to have you back!
    If you want it, I may be able to get you an EGR plate for nearly nothing. I think there's still one on the '74 Grabber I've been plundering at the junk yard.
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    could it be the alternator? maybe it's running off the battery the entire time. You have a voltmeter you could hook up?
  7. 302-72-mav
    302-72-mav Member
    sactown CA
    are you geting any spark if so spray some starter fluid in the carb
    are you still using points in your distributor
  8. justin has a 74
    kentucky
    If you want, ill offer the brand new egr valve and plate for free, just pay shipping. Hate to hear the comets going to waist.
  9. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    An inoperable Comet!? Not on my watch! Hows your dizzy cap? Maverick fired right up after I changed it.
  10. justin has a 74
    kentucky
    Have you checked your fuses?
  11. Mad Goon
    You might also need a muffler bearing, mine went out a couple days ago and the car wouldn't start.
  12. justin has a 74
    kentucky
    May also be a stuck valve but, highly unlikely
  13. Bob Wiken
    Fayetteville, Arkansas
    the =,- anode on the flux capacitor is grounding against the titanic shroud distribution center. a little bondo or duct tape will insulate it.
    Good luck
  14. Mad Goon
    But don't you need to remodulate the spatial resonance pulse width after even touching the flux capacitor?
  15. facelessnumber
    Memphis, TN
    '71 Grabber
    Actually, if you modify the main deflector shield to emit an inverse tachyon pulse, you should be able to create a static warp shell which would collapse the anomaly.
