Ballast Resistor
Discussion in 'Technical' started by Bioinfomatic, May 17, 2009.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    Does anyone know if the Mavericks have a built in ballast resistors to the oem wire harness?
  2. PaulS
    I know that if you have a points ignition there is a resistor wire that takes the place of the bulky ballast resistor. I believe that the DS used the same resistor wire but I can't say that is a fact.
