Ball Joints
Discussion in 'Technical' started by aubman82, Mar 10, 2009.
  1. aubman82
    aubman82 Member
    South Carolina
    1974 Maverick
    Seems like every time I try to get my front end aligned, the shop claims I need something else replaced. Now it's the ball joints. They tell me that to replace both ball joints it will cost $600.00. I looked up the parts and they only cost about $30. How hard is it to replace the ball joints?
  2. rayzorsharp
    You need to find another shop or learn to do it yourself. It's a 2-3 hour job at most. Somebody is trying to make a week off of you.
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Agree with Ray Ray on this one, they are not wanting to fool with it or they a just trying to rip you off.
    Its not a difficult job if you have any mechanical skills at all.
  4. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    I agree with Rayzor, Get the parts and a CHiltons from enay if you dont have one and you can do it.
  5. Bryant
    the hardest part to changing the ball joints is that the uppers are riveted onto the controle arm. you need to grind or chissel them off. the new ones should come with bolts. the lower ones are a whole new lower controle arm and they just bolt in.
  6. mean_maverick
    and if they have been replaced before in the cars life, they're easiesr than that.... simply unbolt old ones and bolt in new ones. like Ray mentioned, 2 hr job at most
  7. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Id say if your mechanically inclined you can do it, just take your time and maybe do some reading.
  8. TUK101
    TUK101 Member
    Elk WA
    72 Maverick 4dr/302 V8, 1963 Ford Custom 500 inline 6
    Our shops around here rape you for that type of work too. I usually just take them in to have looked at just so that I can have a so called professional tell me anything that might be marginal that I can fix lol.
  9. aubman82
    aubman82 Member
    South Carolina
    1974 Maverick
    I thought I was being taken. The shop did say it was the lower ball joints, and the right idler arm. thanks
  10. Bryant
    the lower ball joints are really easy to change.
  11. PaulS
    Most shops replace the whole control arm for liability issues. The cost is higher but then they don't get accused of ruining the front end after replacing just the ball joints when the control arm bushings are bad too.
