Balance Issues, Need a Little Help
Discussion in 'Technical' started by tonyj71mav, Jul 27, 2011.
  1. tonyj71mav
    tonyj71mav Member
    Upper Marlboro, Maryland
    Hello everyone, I have a scenario that needs addressed before I can move forward. I have a 351W that I am installing, the engine was internally balanced when rebuilt with a 164 tooth flywheel that has a "0" balance. I have a 157 tooth Bellhousing with a 157 "0" flywheel. Is this considered balanced set or will I have to go with a 164 tooth Bell housing. :huh:
    Thanks,
    TonyJ
  2. 71gold
    my 347 was...164 balanced...and i switched to a 157...no problems...(y)
    you may want to check with your...engine builder/balancer...:yup:
  3. tonyj71mav
    tonyj71mav Member
    Thanks 71Gold, that is how I felt about it, just tyring to see if anyone has dealt with this issue.
    Thanks,
    TonyJ
  4. tomboy
    tomboy Member
    Your rotating assembly was balanced with the 164 tooth flywheel, but using the 157 if zero balance, won't make a noticable difference.
  5. PaulS
    As long as the flywheel is truly neutral balanced then you will be fine.
    Paul
  6. baddad457
    Ditto, no difference in a zero balanced flywheel/ There's no difference in an externally balanced wheel either in changing size, the size of the counterweight changes to compensate for the extra distance from the crank centerline.
  7. tonyj71mav
    tonyj71mav Member
    Thanks everyone for the support, I thought I was heading out to find a 164 tooth endbell. I appreciate the responses. I seem to take 2 steps forward and 3 back in this swap. I can finally see the end of the tunnel.(y)
    Thanks,
    TonyJ
  8. baddad457
    What transmission are you working on ?
  9. tonyj71mav
    tonyj71mav Member
    I have a C4 transmission with the 157 tooth bellhousing I had to get a V8 endbell when I did the swap I-200-351W. when I got the bell housing I didnot know there were different endbell's to choose from until I started pulling the motor together and noticed that the 164 tooth flywheel was larger than my endbell inside diameter. I had no intentions on buying another transmission just for the endbell, I did that once already.
    TonyJ
  10. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    No big deal on the bell housing and plate, I have a few I would part with.
  11. baddad457
    Better that you buy a 157 tooth flexplate, the larger flexplate would also require that you also buy a matching 164 tooth torque converter as well. You just need a zero balance 157 tooth flexplate.
