bad vibrations
Discussion in 'Technical' started by Grabber5.0, Apr 11, 2006.
  1. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Ok so I've told the story about ordering a new harmonic balancer because I have picked up a vibration. Tonight I pulled off the fan and the pulleys. There were only two bolts left in the crank pulley! :49: The two that were still there were at least 'tight'. Not a ton of torque on them but at least they weren't hanging halfway out. I think I can even see where the outside ring has slipped, and the paint on each piece doesn't line up with the other.
    While I've got it all apart I think I'll finally install those u-joints I've had in my toolbox for 2 years. :biglaugh:
  2. stmanser
    Davenport, Iowa
    good thing you found that BEFORE the pulley failed completely.
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Lucky you.
    atleast you found your vibration!
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    A little duct tape would have taken care of that! J/K :biglaugh:
    Good thing you found it when you did.
  5. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    :rofl2: :lolup:
    should you put thread lock on them bolts? ( I am asking :) )
  6. Grabber5.0
    Kansas City, MO
    71 Grabber
    Well I have to confess I noticed it a while back, probably in the fall, but didn't think much of it. Then when Robert was up here in (was it Feb?) he noticed it and said something about it. I owe him one. :tiphat:)
  7. Grabber5.0
    Kansas City, MO
    71 Grabber
    That's what it says in the instructions for the new balancer (SFI 18.1 btw).
  8. maverick1970
    Missouri
    Hmmm, I have never used Threadlocker on them just a good bolt with a lock washer. I should probably double check mine now that I am running a serpentine setup.
  9. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    always helps to check now and then...
  10. Mavaholic
    Nothing like living on the edge. Of course you could have left it that way until it failed. Then use that as an excuse to buy a new aluminum radiator.
  11. Grabber5.0
    Kansas City, MO
    71 Grabber
    Actually I bought the aluminum radiator 2 or 3 years ago, so I'm covered already. :cool: I just decided to save the hacking for the Grabber's core support. :D
