Bad News
Discussion in 'General Maverick/Comet' started by Rockyou817, Jun 2, 2005.
  1. Rockyou817
    Rockyou817 New Member
    VACAVILLE,CALIFORNIA
    1975 ,4-DOOR, BLUE MAVERICK
    Bad News
    I HAVE FOUND A FENDER AND WOULD LIKE TO THANK EVERYONE FOR HELPING ME I HAVE ALSO RECENTLY RECEIVED SOME BAD NEWS~MY CAR HAS FRAME DAMAGE:cry:! IT MAY BE FIXABLE BUT I DONT KNOW WHAT IS GONNA HAPPEN IT MAY BE A WHILE BEFORE IT GETS ON THE ROAD!
  2. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    whats the damage on it? where? I may be able to help you out in that department a bit. I spent about 6 monthes replacing mine front to back.
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Technically,, our cars dont have a frame. They are unitized construction, meaning what would be a frame is incorporated into the floor of the car. Yes there is something called a subframe which is as close as we get to an actual frame. The entire car falls into the design of a unit-bodied car ( are we learning here?) The roof plays an important roll. We also have the engine compartment which holds the motor,, there are areas that appear to be a frame. That is as close as it gets. I want to help you in assessing what is wrong with your car. Give us some more info and the area of damage, maybe this is not as dark as it appears.
    Dan
  4. Jamie Miles
    Got any pics of how bad this car is wrecked?
  5. rob's74cometgt
    rob's74cometgt Member
    Chilliwack, B.C., Canada
    74 Comet GT
    Pretty much anything can be repaired on the uni-body but if there is structural damage it will need to go to a shop that has the proper equipment to secure the body and pull to proper dimensions, this all of course depending on what the damage is and how bad. Some pic's would help if possible.
  6. Rockyou817
    Im Workin On It
    I AM GOING TO GO OUT AND TAKE PICTURES OF THE CAR TOMORROW TO SHOW YOU GUYS.(y) MY DAD FIXED PART OF IT SO IT WILL AT LEAST DRIVE BUT THE DRIVERS SIDE TIRE STILL KIND OF WOBBLES SO WE HAVE TO TAKE IT TO THE SHOP TO GET A FRONT END ALIGNMENT. AND HAVE THE CASTER CAMBER FIXED.MOST OF THE DAMAGE IS IN THE DRIVER SIDE FENDER AND DOOR.
